disable cli prompting
Description
Disables CLI prompting for the session.
Syntax Description
Default
Enabled.
Usage Guidelines
Use this command to have all CLI user prompts automatically continue with the default answer.
This applies to the current session only.
To re-enable CLI prompting for the session, use the enable cli prompting command.
To view the status of CLI prompting on the switch, use the show management command.
The following command disables prompting:
This command was first available in ExtremeXOS 12.5.
Platform Availability
